Topic: Sample Editor Midi Mapping.
Hi, is there any way to midi map features of the sample editor? (i mean per sample).
mode: one shot, loop
loop: flat, pitched, sync-start, sync lock
trigger: on-off, hold, stutter, unmute
gain
Im trying to map my push 1, the screen is very nice. Small, but nice :D
geposted 48 minutes ago
No, not really.
Besides that, some of these settings can be adjusted per bank (where the entire bank changes mode) or globally. Trigger type is a global setting for instance.
What you're asking is nice for a producer sampler, but not so commonly used on a DJ sampler.
DJ samplers for the most part are "set and forget"
You don't usually change loop or sync mode on a sample "on the fly" if you are a DJ.
Nor a DJ software is the right tool to create samples.. It just gives you the necessary tools to import your samples and organize them in order to use them.
PS: I know it's tempting. I have mapped a few similar units for VirtualDJ and it's tempting to try and follow their silkscreen, but then I always remember that they were made to cover different needs, and we should use them for a different purpose.. ;)
