Topic: Dualmode issue
If frequencies are on outer channels (only way to make stem eq not broken anyway) the filter and gain sliders dont work on those channels. It would be very helpful not to have to revert to another eq mode on inner channels just to be able to use filter slider and just do it on outer channel instead. Better yet, fix stem eq when theyre on outer channels, the top and bottom sliders arent stems.
geposted 2 hours ago
