Topic: [FIXED]VDJ Freezes after 2 seconds
Hi Guys!
Weird issue, since the last update my VDJ freezes after booting within seconds
It seems only the screen freezes, as i still can use the controls on my Traktor Mx2.
The app seems not be running in task manager after the freeze, however the music playing persists. I can only force the program to close by rebooting or resetting windows. However the problems keeps occuring when starting up VDJ again.
I've uninstalled and re-installed VDJ a couple of times, made sure other drivers were properly updated etc. I dont run any overlays as those.
If i'm quick i can get into settings and then the vdj screen stays running, when i close the settings, the freeze also occurs.
anybody else got this problem or know the fix?
I'm doing VDJ on my home PC, i9 285k , Asus Rtx5080 Astral , 64 gb ram
all drivers regarding windows, peripherals and gpu are up to date.
geposted 4 hours ago
Well that was kind of lame. Looks like silly Asus updated my gpu tweak software and switched the OSD back on, which was causing the freeze. Working like a charm again :)
