Finally figured how to fix the Community Chart issue. You used to be able to create a new chart, and choose which of your past played sets you wanted to use to populate that chart automatically. This function became broken quite a few months ago. Thats why when you see on the main user page all the new created charts are empty. Well here is the fix. You have to create the chart, name it, and make sure you select Manual chart when it asks for Chart Type. Then within Virtual DJ go to Ideas> Community Charts> (select the chart you just created) then drag and drop in there the tracks you wished to include in the chart. That will automatically sync with the chart you created using your desktop website login.
geposted 3 days ago @ 11:17 pm
Thank you very much!
geposted 2 days ago @ 10:43 am
Im glad you found this useful. This has been driving me insane for months.
geposted 2 days ago @ 11:54 am
