Topic: Visuals Auto-Change length
Hello,
is there somewhere the option to adjust the time of the auto change of the visuals? As I see it always changes after 16 beats. Is it possible to set it e.g to 32 or 64 beats?
In the native.visuals.ini I found: Switch AutoChange 2=1. But I guess this is only On/Off and has no influence to the length.
Any idea?
Thank you
geposted 40 minutes ago
Script can do it, I have a windows plugin that does it, covering lengths 1,2,4,8,16,32,64,96,128
Are you talking about the audio only visualisation slot or master slot or on deck?
