Topic: Next Update MAC fail!!!
Can´t open the last update on MAC
OSX 26.7.3 (25G342)
it was the update with 3 new fixes with Color FX
geposted 3 hours ago
Specifically b9777 EA is DOA/doesn't startup correctly on Mac and probably needs to be pulled (b9772 works)
Same on Sequoia 15.8.3
Here also with 27.2.1. Had to redownload and install previous b9722.
same. that's why i came.
where do we find older versions?
Same here and had to back to 9729, and it works
en sonoma ninguna! :(
OSX 26.7.3 (25G342)
VirtualDJ build 9777 requests code-signing entitlements that are not authorized by its embedded Apple provisioning profile. macOS therefore rejects the application with the error No matching profile found.
Dead in the water with latest Mac update Golden Gate 27.2.1 on M2 MBP. Cant reinstall, nothing
Went back to 9644 and still wont open!! WTH just ahppened???
