greetings, I updated Virtual Dj and it won't open, an update about reverb waveform something. I do not want to go through uninstalling VDJ again cause ill lose everything and I mean everything, I tried finding the Virtual Dj folder with the files and I can't find it
geposted 5 hours ago
Just download and install again from https://virtualdj.com/download/
I did that, its not opening
shit Bro it open, everything is there and also an update 👎🏾. I had to uninstall the previous version and then reinstall. I aint updating again boss. thanks Bro
geposted 4 hours ago
