I have a question about this script I've been using:
toggle '$SyncMode' & var '$SyncMode' ? setting 'autoBpmMatch' 'always' & deck all quantize_all on & deck all auto_pitch_lock on & deck all smart_play on & (masterdeck ? nothing : sync) : setting 'autoBpmMatch' 'no' & deck all quantize_all off & deck all auto_pitch_lock off & deck all smart_play off & deck all sync off
Sometimes, when repeatedly turning SyncMode on and off during live performances, the master deck would somehow start syncing or drifting in BPM, making the track speed up.
This was confusing because I was protecting the master deck in the script.
Could you please take a look and tell me which command might be causing this behavior? What could be responsible for the BPM drift even though the master deck is protected?
Thanks!
geposted an hour ago
