Forum: Report a bug
Topic: momentary shortcuts
If you press 2 momentary shortcuts at the same time it is no longer momentary. Example I have num 5 and num 6 set as momentart go to cue points. Now it makes for a great cue feature when you select the button to introduce the song however if you select 2 accidentally or switch from one to the other to quickly it lets the song play on.
geposted Fri 13 Jun 03 @ 11:42 pm
Exact you can have several momentary shortcuts pressed at the same time as long as they do not involve the same action.
This is due to the way the mementary is implemented: it stores the value to bring back when the key is released in an array indexed by the action.
If you really find it to be a problem, I can still change it.
If you changed it what effect would it have on what it does now besides cancel out when 2 buttons are pressed ?
