hi...this is djtsatsos007 from greece.
there are several probs that i faced while surfing in the site and while using atomix.
1)i can't change the new skins that i've downloaded
2)i can't remember the password i once edited(and i can't find a way out to review it from any options in the site)
3)how can i upgrade my version of 2.0 to 2.1.1??
i appreciate any help djs...
geposted Sun 15 Sep 02 @ 9:18 pm
1) Unzip the downloaded zip file into the root folder of Atomix under skins
2)Email service@atomixmp3.com from your registered e mail address for your password
3)You will be allowed to upgrade once you sort out your password problem.
.:DJ Homeboy:.
.:DJ Homeboy:.
geposted Sun 15 Sep 02 @ 10:25 pm
.:DJ Homeboy:.
.:DJ Homeboy:.
geposted Sun 15 Sep 02 @ 10:26 pm
Why is the site slow today, said gateway error then it double posted my message.
.:DJ Homeboy:.
.:DJ Homeboy:.
geposted Sun 15 Sep 02 @ 10:27 pm
thanx a lot..djhomeboy
geposted Mon 16 Sep 02 @ 5:53 pm
one more question...i 've already unziped under atomix file...but as soon as i choose to change skin,the program closes!!
geposted Mon 16 Sep 02 @ 5:57 pm
is there a way to pre-listen to my headphones a song on deck A,while on deck B,let's say,the sound goes to the speakers.
--i've got sounblaster live
--i've bought a double thing put to the soundcard's line in,and at the one side i plugged the headphones and at the 2nd hole the speakers...just like i've seen at http://atomixmp3.online.fr/config
geposted Mon 16 Sep 02 @ 6:36 pm
thanx to djhomeboy concerning my lost password..
geposted Mon 16 Sep 02 @ 6:40 pm
first, that feature will only work with the full version, not the demo. 2nd, you have to change your sound configuration to 1 sound card, & headphone/speaker.
geposted Mon 16 Sep 02 @ 6:41 pm
Another stupid person...
sorry mate, I'm in your boat
Liam
Liam
geposted Tue 17 Sep 02 @ 2:15 am
impressionsdj...i have not the demo version ....and i already have changed the sound option!!!!!!
--liam thanx 4 understandin'
geposted Tue 17 Sep 02 @ 3:36 pm
impressionsdj....as an experienced member,your expert skills and advices doesn't seem to help me!!
geposted Tue 17 Sep 02 @ 3:39 pm
I just threw out a couple of reasons why what you were trying to do may not have worked. Perhaps it didn't help you, but I tried to offer up an explanation. Sorry I couldn't be more helpful, but remember, I'm not on the Atomix payroll. I'm just a guy who uses Atomix a lot. Someone vaguely describes a problem, you start by offering the most obvious solutions. If those suggestions don't work, you move on to less obvious solutions.
Good Luck man!
Good Luck man!
geposted Tue 17 Sep 02 @ 4:18 pm
Well said Impressionsdj, some peeps could learn a bit from that reply!
Liam
Liam
geposted Tue 17 Sep 02 @ 11:29 pm
