Forum: Old versions
Topic: Dropzone vs. not a Dropzone
Just noticed something annoying that should be fixed somehow:
if you accindentally grab a file in the playlist and drop it outside of the playlist but not inside one of the dropzones the file disappears from the playlist.
I haven't tested it out yet but one way to go around this problem with accindentaly "lost" songswould be do make every non-dropspace-area a dropzone with a chan="playlist" setting to put everything dropped back into the playlist... would that work?
Let's say you want to scroll the playlist and accidentally grab a file instead (DJ's are no strangers to stress) or want to drop it on one of the decks but miss the dropzone (if they did it in Armageddon you can do it in a smokey club filled with jittery feelings :).. the file is then lost and has to be found by browsing the harddrive for it... NOT GOOD!
geposted Tue 09 Apr 02 @ 4:53 pm
