Hey all, could someone direct me to some WDM drivers for my SB Live Value card, im runnin ME, and i need to use software 3D when runnin atomixmp3 which must be slowin my poor AMD 500mhz down a bit........
thanx all,
.::DJ Ben Jammin::.
thanx all,
.::DJ Ben Jammin::.
geposted Sun 28 Apr 02 @ 11:58 am
Hi Nero. It's me again. I have read some urls on these forums about the wdm drivers:
http://shs-sound.paraknowya.com/
http://www.winoscentral.com/article.php?sid=2439&mode=thread
Hope it helps.
Hope it helps.
geposted Sun 28 Apr 02 @ 10:59 pm
If your using Win98SE, I *STRONGLY* suggest you DONT use the WDM drivers. I already had to re-install 98SE because of the WDM drivers. ;)
Grimm
Grimm
geposted Mon 06 May 02 @ 7:28 pm
WDM drivers aren't supposed to work with an OS less than Win2k, because WDM is a new MS driver model (quite complicated to explain. if you want me to, just ask). So it's normal you can't find WDM drivers for win98, or that they don't work.
geposted Mon 06 May 02 @ 9:22 pm
Actually, WDM drivers work with 98SE, not the orignal 98 though. 98SE introduced the WDM drivers, but Creative as always just sat around and made zero updates to thier drivers. As I said, the newer Live! 5.1 and Audigy sould have WDM drivers available. But the older Live! 4 channel cards are still stuck with VXD drivers.
And you can't just download the 5.1 WDM drivers and install it on your older Live! card. The drivers can recognize which card is installed. Hence, why theres hacked WDM drivers available for the 4 channel cards.
But all that doesn't matter to me, since I'm going to get a Terratec 6-Fire DMX 24/96 card. :)
http://www.terratec.com/ttus/default.htm
Now if only Atomix would use the MAD mpeg decoder...
http://www.mars.org/home/rob/proj/mpeg/
geposted Tue 07 May 02 @ 11:25 am
I played around for a while with MAD (for one of my own projects). It's not really very fast I think... Xaudio is also easier to use and to maintain (and to stay up-to-date).
geposted Tue 07 May 02 @ 8:06 pm
And also the worst sounding encoder/decoder out there. It may be partly based on the mpg123(?) lib, but it still sucks. ;)
Grimm
Grimm
geposted Thu 09 May 02 @ 11:35 am
Then again, I think they've tried to clean up the decoder abit, so Xing may be the worst now, but its still not MAD quality, or for that matter even Fraunhofer quality, which is below Lame. ;)
Grimm
Grimm
geposted Thu 09 May 02 @ 11:38 am
I have bought a second sound card for resolve the problem. I had the same one with a SB1024 on w98se. Try it, there is the value/Sb1024 unofficial driver. Be care, beats skippings! So, try this too: Start/execute and reduce the material acceleration in Song. The problem should be resolved. See ya. Tell us what.
(type "creative driver unofficial" in google engine)
I'm Belgian... Sorry for this bad English... :))
geposted Tue 14 May 02 @ 12:40 pm
Erratum:
Start/execute and type DxDiag. In there, reduce the material acceleration in Song.
geposted Tue 14 May 02 @ 12:57 pm
One 3d Card ask wdm driver for phones + headphones. With 2 cards (for example: SB Value/1024 for phones + PCI 128 for headphones), some wxd drivers run corretly, without beats skipping. So, with 2 sound cards and wxd driver for w98se, enjoyt it!
I prefer w98se and 2 sounds cards for run correctly Atomix 2.1 to w2000/wXP (that two are bigger than w98se). With that one, the scroll is not abrupt. In fact, the multi-boot is the best soluce for optimal performance, without many programs installed on w98se.
My config: p4 1.8A + 256 DDR + w98se with only Atomix runs and I never know bugs or problems either Atomix 2.x nor 1.x.
geposted Tue 14 May 02 @ 1:22 pm
About the unofficial driver: these runs correctly!
In fact, delete all creative .wxd files and THEN install the unofficial. A friend has make that and all runs right
Phenryll - TMop - The wdm driver doctor! :))))
geposted Tue 28 May 02 @ 6:24 pm
It's here: http://shs-sound.paraknowya.com/
I have downloaded these and no problem.
geposted Tue 28 May 02 @ 6:26 pm
Strange, I am running Windows 2000 Server with two SB sound cards, Live Value! and PCI 128, and both are using the WDM drivers from Creative.
geposted Tue 18 Jun 02 @ 12:49 pm
:)) Try to Install Windows XP Professional :P
geposted Wed 02 Mar 05 @ 7:02 pm
deejaysoft2004 you answer to a very old post: may 2002
geposted Thu 03 Mar 05 @ 4:17 am
