For the second time now I've encountered this problem - why? + cure please
geposted Tue 21 May 02 @ 6:55 pm
You should delete that file in the atomixmp3 main folder.-
geposted Tue 28 May 02 @ 3:27 pm
@ teamers or voluntarees :
Would a backup-copy of the database work?
For instance if you copy your database right after you've scanned all your MP3's just in case it should go corrupt during a live gig?
(not asking for myself, this is just a hint to the team and those who fear this problem)
geposted Tue 28 May 02 @ 3:42 pm
yes in that way is working just delete the problematic one and copy paste in the atomixmp3 folder the backuped
geposted Wed 19 Jun 02 @ 2:41 pm
hi..i cant edit any comments..always come with internal database corrption...isnt there a fix...pplssssss..deleteing the files is no good...cos i want to edit comments again..
geposted Fri 12 Sep 03 @ 5:37 pm
yes... this is a very big problem :(
On that case if the PC is clossed by unknown error or the energy surse is down, if the AtomixMP3 is playing... the atomixMP3 Internal Database is corrupted !!!
Yes, if u have a backup file, no problem, but in example, i have more then 2000 files with BPM and CUE song on that file....and for example... if the PC is crashed one more in week, u need to beat that song on everyday :)
Need an answer for this... or a little soft to correct that errors.
I think is need to write back that file... in real time...when u CUE a song :)
Best Regards,
G.
Best Regards,
G.
geposted Wed 02 Mar 05 @ 6:53 pm
