hey all
i have a PII 350
a 6 gig drive (pretty full)
64 meg ram
SB live value
and a external Numark DM900 bluedog (dogdy) mixer..
what should i upgrade next..??
tanx all
DJ NERO
i have a PII 350
64 meg ram
SB live value
tanx all
DJ NERO
geposted Mon 26 Mar 01 @ 11:30 am
Nero your system should be fine but you can definately make some adjustments. It might be wise to invest in a new hard-drive since yours is full. Look for a 7200RPM model - the IBM or Maxtor drives are a solid choice. Next you should really get some more RAM, 64MB is really bare minimum. You should see a good preformace gain (and less hard-drive racket) if you bought a new 128MB stick, giving you a total of 192MB.
geposted Mon 26 Mar 01 @ 7:08 pm
Personally I'm runnin a 700 Athlon
13 Gig drive (really full)
192 mgs RAM
SB Live Value
And I have problems some times... So I think you can never have to much power.. next upgrades.. Ram & HD.. but if your think it's the most important components personally.
192 mgs RAM
SB Live Value
geposted Mon 26 Mar 01 @ 9:09 pm
thanx bros
i will probably opt for a shitload more ram
and a second hard drive..
bye the way does atomix need a guy in Australia??
coz i live in Sydney!
thanx all
DJ-NERO!
thanx all
DJ-NERO!
geposted Tue 27 Mar 01 @ 2:11 pm
Get 512Mb of SDRAM if your motherboard can take it. Then buy a Pentium 4 1300Mhz. Get a huge and very fast SCSI hard drive, add to this one of the latest and greatest sound cards. Yous should then have no problems whatsoever, if you do then i suggest buying a computer off NASA, and from my experience that is what you need to do in order to run atomix with no problems.
As to whether the Team need an ozzy bloke, well, I don't know or care.
G'day Mate
G'day Mate
geposted Fri 30 Mar 01 @ 9:18 pm
Thanks for your great and anonymous suggestions. That´s what we need to make AtomixMP3 better.
For those users who understood the sense of a forum:
I run AtomixMP3 on a PIII@500 with 128MB RAM without any problems. Most problems depend on a system, full of trash, left by deinstalled software. Try to optimize your registry, clean your HDD, defrag it and deinstall all software you never used (that´s mostly enough ;-))!
But your RAM should be a bit more. 128, better 192, should be enough.
mama
mama
geposted Fri 30 Mar 01 @ 9:27 pm
THanx mama
im cleanin it up @ present
geposted Sun 01 Apr 01 @ 10:58 am
No prob!
For requests to be a team member, please go to the team site and click on the teamapply link.
mama
mama
geposted Sun 01 Apr 01 @ 11:34 am
Hey ive decided on re-building my system...
but wot should i get
im trying to decide whether to get an
AMD Athalon 1000Mhz
or PIII 866
i will most probably get
PIII 866
Gigabyte GA-6VXc7-4X motherboard
128Mb 133Mhz ram
Sound Blaster Live! (from current puta)
voodoo 2 12 mb (from current puta)
does it sound good?
should i go AMD or Intel????
DJ Nero
AMD Athalon 1000Mhz
or PIII 866
PIII 866
128Mb 133Mhz ram
does it sound good?
DJ Nero
geposted Mon 02 Apr 01 @ 12:53 pm
buy a PIII
it's better to play dvd and mostly DivX
for games it's quite the same
An other thing but this time is really a detail: PIII is much cooler than a AMD processor.
But u should buy 256SDram (very cheap for the time being)
note:I got a p3 800 with 256 ram, works great
U can overclock it at at least 866, but u can get higher
by increasing the voltage of the CPU(checkout the net for more info)
geposted Tue 10 Apr 01 @ 1:02 am
