Ok! I like your program, Ok! I Wanna buy it! but what the hell is going on with the sound quality? I have all my MP3's files in 128's, bu when I mix through another song the sound just Muffles??????????????
How can I fix this problem?
geposted Sat 31 Mar 01 @ 8:57 am
Set pitch range to +/- 8% , disabled master tempo,
improve your directx with lastest version...
As many things you can do if you want better quality!!!
geposted Sat 31 Mar 01 @ 10:55 am
Whenever I'm mixxing with the atmoix mp3 program it sound on the program are very low and my speakers are on the max and trust me the speakers are loud, for example on winamp its blasting on my speakers but whenever the atomix is up the sound is very low. any suggestions on how i can fix this?
geposted Tue 17 Apr 01 @ 12:58 am
check in the volume control to see if the wave volume is at maximum or nearly at it. if not set it at 90%
(on both card)
cTiger
(on both card)
cTiger
geposted Tue 17 Apr 01 @ 8:23 pm
