i'm considering in purchasing your excellent program but would find these
questions extremely usedful if u can answer them A.S.A.P :
1: ) if i pay the $60 do i still get free update or need to pay another
$60 for an update
2:) i live in the UK so how would that work , still pay by credit card ( VISA) and the bank would do it all .. how much would it cost i worked it at around £40 .. does that sound right ?
3.) i have a soundblaster live player just a standard one, so can i listen to 2 songs at once with this soundcard then ? ( i have heard people having a lot of problems with the sound via 2 outputs ? )
4.) now, as i have 2 outputs from my soundcard one goes directly into my hi-fi where i record straight onto tape, can i still do this as i assume one would be headphones other would be the normal speakers so how would i record
onto tape then ?
Snow-Munki
geposted Mon 16 Apr 01 @ 10:11 pm
          1) yes, you get free updates
2) ?
3) use the "speaker" output to go to your "hifi" and use speakers connected to your "hifi" instead of the ones for your computer.
    2) ?
geposted Tue 17 Apr 01 @ 6:57 am
          Hi,
almost any problems with soundcards depend on the usage of cracks, a non upgraded DirectX, or wrong settings in the sound config.
If you don´t use a crack, purchased the software and set the config you use, all works fine.
To listen to the music you mix, the above description is right.
mama
mama
geposted Tue 17 Apr 01 @ 7:22 am
          hi i use ur automix i would ask u if u have a new upgrate at this time   samirdelta     a dj samir younes
    geposted Fri 20 Apr 01 @ 1:00 pm
