When I have the auto mix feature enabled the mix starts to fade out with about 20-30 seconds left in the song. I DJ an oldies show where the songs are only 2-3 minutes long so I really do need those seconds.
Is there a way to adjust the auto feature to mix automaticaly in the last 3-5 seconds of a song?
Thanks!
PS. I am running the full version...
Thanks!
geposted Wed 10 Oct 01 @ 9:28 pm
You can change it in the config. There is a setting called "mix length".
geposted Wed 10 Oct 01 @ 10:42 pm
I have it enabled under "short" but find no different-are you sure that mix length refers to when the song is mixed out and not the length of time it takes to mix between the songs?
Thanks
Thanks
geposted Thu 11 Oct 01 @ 8:59 pm
