Hiya guys,
Download this...
http://syfoon.gotmaryjane.com/music/Syfoon_-_Bacon_n'_Eggs.mp3
Mirrored at;
http://www.noiseport.org/Syfoon_-_Bacon_n-_Eggs.mp3
(Be warned, its 50.2MB, and, for the lil wimps out who might get scared unless I warn you, it contains some swearing *gasp* :P)
Tell me whatcha think of it?
(Good DJ's - Reckon the mixes are any good?)
Cheers,
- Bren (Syfoon)
Download this...
Mirrored at;
Cheers,
- Bren (Syfoon)
geposted Mon 14 Jan 02 @ 11:56 pm
Did you do this mix? It's awesome!!!!!!!!! Can I play it at an upcoming gig?
geposted Tue 15 Jan 02 @ 1:09 am
Very Good. Any chance of a track listing? Was this done on Atomix? If so, what version?
geposted Tue 15 Jan 02 @ 11:21 am
Yep, I did mix it :)
It would be a lot easier for me if you just contacted me via AIM or e-mail...
http://www.syfoon.com/contact/
- Bren (Syfoon)
- Bren (Syfoon)
geposted Tue 15 Jan 02 @ 10:59 pm
Dude you never fail to impress me! Don't stop rockin! :)
geposted Wed 16 Jan 02 @ 2:42 am
What's going on when I input either of the two addresses you gave me for the mix? When I type it in IE, it does the 'page loading' thing with cursor turned to egg-timer. In the bottom left-hand corner of the IE wndow there is a hard drive icon with a small red arrow pointed into it. Does this mean it is downloading? and if so, where to?
I left it for ages and when I came back the page had stopped 'loading' and was blank. I did a search for the mix but found nothing. I then clicked on 'refresh' which brought up a player on the webpage which then proceeded to start playing the mix. Didn't it even download the mix to a TEMP folder? I cannot find the mix on the hard drive anywhere at all. I just want to download it and be able to play it in WinAmp or something.
What do I do????
Thanks
What do I do????
Thanks
geposted Thu 17 Jan 02 @ 6:48 pm
To download the mp3 enter this in your browser address bar,
Then right click on 'Syfoon_-_Bacon_n'_Eggs.mp3' and select 'save target as'
Hope this works for you.
geposted Fri 18 Jan 02 @ 10:45 am
Thanks, that worked perfectly. It was an obvious answer, I can't believe I didn't think to do it. Doh!
geposted Fri 18 Jan 02 @ 2:49 pm
Just started listening to the mix, so good so far. You must give us a tracklisting!
geposted Fri 18 Jan 02 @ 4:23 pm
Is this made using Atomix???????
Greetz, ikke PS: nice job!
geposted Fri 18 Jan 02 @ 6:10 pm
Can anyone PLEASE tell me the name of the last tune in Syfoon's mix?! PLEASE!
geposted Sat 19 Jan 02 @ 5:09 pm
WOOOOOOOOOOO relaxed !!!!!!!!!!!!!!
Go girl go girl YEAAAAAAAAAAAAH this song rockss
geposted Tue 22 Jan 02 @ 9:55 am
Dude, this stuff rocks!
How did you do it? I'm a professional DJ in the Netherlands but I never heard such fine mixing.
Keep up the good work....
geposted Sat 02 Feb 02 @ 6:57 pm
Simple, I've been doing it a looong time :)
- Bren (Syfoon)
- Bren (Syfoon)
geposted Sun 03 Feb 02 @ 2:12 am
