Hi all , can anyone help me ?? When i record my mixes on Atomix , i cannot playback these mixes as my pc will not recognise which format they are in , can you suggest anything ............ cheers..............marko
geposted Fri 22 Feb 02 @ 9:12 pm
AtomixMP3 saves mixes in the Microsoft PCM wave format..
Nigh on all players can play this, including Atomix
Try,
http://www.winamp.com/, that will play almost any audio file you can find (including .ogg's... with the rght plug in ;))
- Bren (Syfoon)
Try,
- Bren (Syfoon)
geposted Fri 22 Feb 02 @ 11:01 pm
Atomix only plays Mp3 files back, yet records your mixes into wav format. You just need a software to convert that wav file that you mix into an Mp3 file so it will play back. Try CD-n-go software. It's free and works perfectly. I use it constantly. It's at http://www.cdngo.com/2/download/download.html
geposted Tue 05 Mar 02 @ 12:30 am
