is it possible to make your brake and swirl up effect be able to have a song selected so when it swirls up again it starts the song selected?
geposted Wed 06 Nov 02 @ 7:41 am
not for the moment
geposted Wed 06 Nov 02 @ 10:38 am
ok, but did you get what i meen?
geposted Thu 07 Nov 02 @ 4:57 am
Yep I understood what you mean. We'll see what will be possible in the future.
For now you can always activate the effect on both tracks (the mix-out & mix-in) at the same time and flip the crossfader at the moment it inverts direction. This is giving the same result.
Rgds,
DJ Corpse
Rgds,
DJ Corpse
geposted Sat 09 Nov 02 @ 10:38 am
yup, i wored that out and got the effect that i wanted ;)
CyA
CyA
geposted Sat 09 Nov 02 @ 12:41 pm
my brake and swirl up dont work it just have a blank thing like the plugin isnt there
geposted Sat 10 Jan 09 @ 11:06 pm
This is a really really old post - what version of VDJ are you using, and where did you get the plugin from?
geposted Sun 11 Jan 09 @ 10:08 am
vdj 5.2 pro
geposted Fri 30 Jan 09 @ 1:05 pm
dizon7th wrote :
vdj 5.2 pro
Then pls register ur serial in ur modify your profile and then u can download the goodies available for u;)
geposted Fri 30 Jan 09 @ 1:17 pm
