Hi i just bought Atomixmp3 2.1.1 and im having a problem loading effects. I downloaded the "Hallway echo" but i cant load it to the effects section of atomix. i only have 3 effects which are the flanger, pan, and brake.
please... help me......
geposted Thu 14 Nov 02 @ 3:48 am
you need to go into any folder on your computer and click "view" then "folder options" then click the tab saying "view" and make sure that "show all files" is selected
then go into atomix and into the effects section and select the effect to change and go to the folder you saved the downloaded effect and select the one you want to use!
geposted Thu 14 Nov 02 @ 7:35 pm
thanks dj walkers............
geposted Fri 15 Nov 02 @ 7:00 am
no problems! :-)
geposted Fri 15 Nov 02 @ 8:36 pm
