I noticed that everytime I load the flanger effect there is a time when the bass gets hard. I've downloaded the flanger source code and tried to make that effect but I lack of programming experience. As of now, I only know BASIC programming.
Is it possible to make an effect that makes soft bass hard out of the flanger effect?
Or is it possible to make a plugin that enhance bass?
It would be a great help for our mobile sound system.
thnky,
thnky,
geposted Tue 26 Nov 02 @ 3:58 am
So what you want is a Bass Boosting plug-in ?
OK, I've added it to the list.
Kind regards,
DJ Corpse
Kind regards,
DJ Corpse
geposted Tue 26 Nov 02 @ 10:00 pm
thanks!
geposted Wed 27 Nov 02 @ 2:36 am
Just to add another point. I love the flanger lite but it is sometimes a problem that it over-boosts the bass when you use it over the beats of a track rather than a build up part - do you know what I mean? It would be nice if the effect could be configured with a frequency range to apply the effect to - so you can confine it to high and mid frequencies if you want. What to you think? Is this easy to do?
geposted Thu 28 Nov 02 @ 11:24 am
