Something great for the audiophyles in here:
It's a really great plugin ... If you set the setting just right ... I can REALLY enhance the bass (no this isn't just another "EQ")
http://dee2.prv.pl/d.php?e=thx&v=120
Check it out. Although I don't know what much of the controls do ??? It takes alot of time finding the 'sweet' spot since the changes don't take effect right away (takes about a 5 seconds to notice a change when the controls are adjusted).
BTW: It can be used with Winamp 2.xx and 3.xx in addition on Media player 9. Altough It works best with Winamp 2.xx !!! Don't use Winamp3 ... it's really really unstable.
Too bad we cannot incorporate this into Atomix ... It'd be REALLY sweeet.
geposted Tue 28 Jan 03 @ 12:43 am
