Hi,
I download the full version yesterday and it's been one problem afther the other,. I finally figured out how to downloasd skins and have been trying them. Now when you click on AUTOMIX,it does not open up, it minamizes and won't open. You can only close it. I have t on a e-machine pc amd 2000, 512 ddr, 80 gb windows XP
Thanks
Andy
Thanks
Andy
geposted Mon 11 Aug 03 @ 3:36 am
It seem your problem come from your screen configuration. If you use the 800x600 size, be sure you use the same format skin (the 1024x768 format can freeze your monitor)
Coyote
Coyote
geposted Mon 11 Aug 03 @ 4:03 am
Thank You Coyote,
I switched it 1024x768 and it opened.
Thanks Again,
Andy
Thanks Again,
Andy
geposted Mon 11 Aug 03 @ 4:32 am
