when i try to stream a set live via shoutcast the left and right levels are completely different my right channel works fine but the left channel is totally distorted.
the only way i can find of gettin round this annoying problem is by recording the mix befor hand and then using a recorded mix streamed via winamp + shoutcast
any idea's
p.s it has all gone terribly wrong since windows xp was installed as far as i know
any idea's
geposted Tue 19 Apr 05 @ 6:24 pm
