Forum: Old versions
Topic: Atomix shows songs as beatmatched, but audio lags
I’ve just downloaded Atomix on a new PC that I’ve bought for a family member. It’s a SB Live 24bit soundcard. The PC is a Celeron 2.5ghz with 512mb of RAM.
I am having this problem where once the songs are beat matched, the display window shows they are beat matched however over the speakers they are off beat a very small about, as if the sound is lagging only a bit.
Would this be a software setting or something to do with another part of the PC? I’ve used the software fine on other PC’s… im going to try my older SB Live soundcard tomorrow which I know has worked flawlessly with Atomix in the past.
I just thought I would post on here and ask if anyone else has had any other problems, and how they solved it?
geposted Sat 30 Apr 05 @ 1:37 pm
