I've had this happen a couple of times now. Everytime I start recording what Im mixing, I am never able to open any of the files in the playlist except the two that automatically load onto the decks when I first load the playlist into Atomix. Every file I drag to a deck says Impossible to Open File, yet when I do the same things except not recording, I have no problem. Can anyone help me out with this??
geposted Fri 01 Jul 05 @ 2:29 am
Do you have a cracked version?
geposted Sat 02 Jul 05 @ 8:59 am
It could be a cracked version, I got it off a friend. I downloaded VirtualDJ demo off this website, and I have the same problem
geposted Sat 02 Jul 05 @ 10:52 am
I think maybe you should buy atomix. That way you KNOW you will get a full working version.
The only other thing I can think of is that while you are recording Atomix won't let you drop another tune into the deck you are recording from.
You may want to check out your configuration too
geposted Thu 07 Jul 05 @ 9:26 am
