I just upgraded to version 3.1 today and noticed that the volume on the live deck changes (gets lower) when loading the other deck. I do not recall this happening in 3.0. I am using the same PC so nothing has changed. Also how do I get the live deck to auto switch on fade. Any insight would be much appreciated
Thanks
Thanks
geposted Fri 12 Aug 05 @ 6:20 am
Have you tried to change auto-gain settings at configuration menu...?
geposted Fri 12 Aug 05 @ 2:11 pm
This does happen if the track was not analyzed. Analyze your track and it will go away.
geposted Fri 12 Aug 05 @ 4:47 pm
To activate the automix you can click the star at the top of the playlist window.
geposted Fri 12 Aug 05 @ 6:38 pm
Thanks guys! Everything now works perectly!
geposted Sat 13 Aug 05 @ 9:04 am
