HELLO
CANT GET DECENT SOUND FROM MY VIRTUAL DJ SOFTWARE AT LARGE GIGS, LOW OUTPUT TO AMP AND EVEN THROUGH A DECENT MIXER PIONEER AND TECHNICS LOW VOLUME.
NEED TO BOOST SIGNAL SOME HOW ? SUGGESTIONS APPRECIATED.
THANKS FORUM
RUFUS RUFFCUT UK
RF RECORDS
THANKS FORUM
RUFUS RUFFCUT UK
RF RECORDS
geposted Mon 15 Aug 05 @ 2:21 pm
hmm,
welcome to forums,
please don't shout (write all in caps)
try to adjust the settings of your soundcards (in windows mixer) many cards have set it to middle by default which is very silent.
Does other software (like winamp) play much louder ?
What soundcard do you have ?
welcome to forums,
geposted Mon 15 Aug 05 @ 3:14 pm
I think this problem isn't associated to VDJ. Which version are you using?
geposted Mon 15 Aug 05 @ 6:27 pm
get a professional soundcard such as an m-audio or a maya44. these have the professional signal level outputs so they put out asmuch gain as a pro cd player. this will fix your problem
geposted Tue 16 Aug 05 @ 6:43 am
hi!
I've got the same problem...with the DJ Console. The signal is much so low. So the signal screen at my pioneer mixer never reaches the red area; but it should, because the pioneer mixers are made for that, I think.
regards
Andy
regards
Andy
geposted Wed 17 Aug 05 @ 6:38 pm
This is a common problem associated with three things.
1. Cracked versions.
2. Poor soundcard.
3. bad settings.
Mixer is not the place to look.
2. Poor soundcard.
3. bad settings.
geposted Wed 17 Aug 05 @ 7:00 pm
Get a Sonic Maximiumizer. It cost about $189 but it is well worth it even if you are still using cds or records. I had the same issue and tried everything all the others post have. This is a great solution.
geposted Sun 28 Aug 05 @ 12:01 am
