I just bought the hercules DJ Console but when I install the software, and it says to plug in the Hercules DJ Console, nothing happens. The lights go on, but they do not flash as they should. The cpu usage is at about 50% for ages, and sometimes if I leave it for 10-15 minutes the lights will flash but the install will not go any further. I am using the latest drives downlaoded from the hercules site.
Anyknow know how i can get this to work as I was so excited to start using it and I've been trying to get it to work for 3 days now and to no avail.
Thanks
Thanks
geposted Sat 20 Aug 05 @ 4:07 pm
Hello,
looks like your DJC is not working properly....which is the config of your PC? memory, processor....?
geposted Mon 22 Aug 05 @ 12:38 am
try takeing it out and installing all over when it tell you plugin the controller plug it in and just let do it it thing and should do it
geposted Mon 22 Aug 05 @ 6:53 am
Sounds like your computer is rejecting the console and for good reason! lol
geposted Tue 23 Aug 05 @ 5:38 pm
