on the opposite deck. Everytime I load a track to cue the sound being heard in the room cuts out for a second. Is this a memory issue. Right now I am running 512. sometimes when I put the needle on the deck being cued the sound cuts out as well.
Anyone else have this problem.
geposted Sun 21 Aug 05 @ 8:34 am
"Everytime I load a track to cue the sound being heard in the room cuts out for a second" - i'm also running on 512 ram & I am having this happen sometimes not everytime only in tcv mode. i'm also running on 512 ram. not sure why... anyone else know???
geposted Mon 22 Aug 05 @ 3:48 am
try set your latency a step slower in asio control.
geposted Mon 22 Aug 05 @ 8:01 pm
Are your files analyzed?
Does it do it just once or several times as the track loads up?
geposted Mon 22 Aug 05 @ 8:06 pm
Yes there you have it just rememberd, when the files is not analysed it "hack" the audio when loading.
geposted Mon 22 Aug 05 @ 11:04 pm
If analyzing the tracks before hand doesn't do it I personally feel that 512 isn't enough for TCV. I know some people are running well with it but unless you have a perfectly clean and well performing computer I think you will have problems. I had similar problems with locking up and sound cutting off on load or when using a sample and an effect at the same time, etc. but they all went away when I added another 256 of ram.
geposted Fri 26 Aug 05 @ 3:04 pm
