i have compaq PC aith 6 outputs on its back side.
pls tell how can i listen a song before mixing it actually.
pls explain it breifly.
also tell me that how can i play only music in the song and omit the vocals.
pls reply soon
pls reply soon
geposted Thu 25 Aug 05 @ 1:32 pm
Hi nadyrocks,
You could get a lot of information in this 2. Put ACAPELLA in the General Forum and find the responses and explanations.
For the headphones, change the current sound card selection in VDJ. And Select the 4.1 ilustration. Some sound cards like Sound Blaster, need to be configure in 5.1 in order to listen properly. If you don't do that you will hear the cue song in the master output.
Good Luck!
Good Luck!
geposted Thu 25 Aug 05 @ 2:22 pm
acw, probably you meant Intrumentals :-)
nadyrocks, you can use plugin vocal+ tahat can remove vocals or remove music
it works in some songs pretty good
geposted Thu 25 Aug 05 @ 3:48 pm
The EQ is also a useful tool in dipping the vocals, the mid range requires only the smallest turn anti clock wise and already the vocals are sub dued, also a note that you lose the leads, keys etc when you cut the mid section.., you can learn more about EQ in the mixing lessons forum.
geposted Thu 25 Aug 05 @ 3:57 pm
@Lopez, I see information in this matter when I search for acapella, but "instrumental" most work too. ;-)
geposted Thu 25 Aug 05 @ 4:09 pm
