Hi All,
Is there a way to disable the history plalists?
geposted Fri 26 Aug 05 @ 9:04 pm
I don't think so... but the red playlist folder in the browser is just a "favorite" folder, you can (right click) remove it from favorite if you dont use it. Then you can go to the physical folder and delete the existing playlists. New playlist will created again though, but you will not see them.
geposted Sat 27 Aug 05 @ 2:50 am
