Hi all,
can someone help me i want to perform a few actions via a plugin.(i.e GetParam and send command)
1) get the current playing deck and the song title.
2) load a song by file name to the first place in the song queue(playlist).
3) load a playlist.
10x alot in advance.
3) load a playlist.
geposted Mon 29 Aug 05 @ 7:15 pm
1)
"get the current playing deck": it is not possible. Otherwise here is some data:
#define PLUGIN_DECK 0
#define LEFT_DECK 1
#define RIGHT_DECK 2
int Deck;
GetParam(PLUGIN_DECK,"CurrentDesk",&Deck);
"song title":
char title[100]; // maybe it's too little
GetParam(PLUGIN_DECK,"Title",&title);
2) impossible: dev team should add a parameter for browser_toplaylist() for that (for example: if value \<0 load to the first place)
3) impossible, there is no function to load a song from a filename
#define LEFT_DECK 1
int Deck;
"song title":
geposted Wed 31 Aug 05 @ 8:23 am
How do I write this Char[100] array of characters to a registry key or to a file ?
Is there a C++ command to convert a char[] array to a string ? It doesn't seem to work...
I would like to write the current playing songs (names or filename) to a registry key, so i can access it with a better or easier programming language like vb.
thx,
Doc.
thx,
Doc.
geposted Tue 06 Sep 05 @ 8:22 pm
