hi, well i been using this awesome proggy for a while now and i'm real acustomed to all the settings n stuff ..but why when i go to record .. and when i finish recording to listen to how it came out ... some of the song is choppy/skipped ..why is this??? i use the lame mp3 encoder but is there another 1 out there thats better?? or is this caused by something else... plz if some1 could help me out w/ this problem i would be very thankful..if you need to kno my hardware specz just ask me i'll let you know right away... again thank you
geposted Fri 09 Sep 05 @ 5:47 pm
yes the hardware spec are needed and the version of Virtual Dj software. This chops are usually caused by slow PC's or cracked versions.
geposted Fri 09 Sep 05 @ 6:58 pm
windows xp pro sp2
AMD Athlon 64 Processor 2800+
1.80 GHz
512 Ram
Soundcard - Vinyl AC'97 Codec
Videocard - Geforce 5200 FX
virtual dj version 3.01
hope this helpz
1.80 GHz
512 Ram
hope this helpz
geposted Fri 09 Sep 05 @ 8:27 pm
