Hi I'm planning on buying virtual dj 3.10 and I was wondering can we get a multiple license to instal it on 2 computers
also does the coded vinyls from final scratch or any other will work, AND WILL IT WORK WITH FINAL SCRATCH 2 amp
can we buy those coded vinyls in a regular store, and where can we buy them
I've tryed with fs2 vinyls and the song are playing at least at 10bpm faster
geposted Fri 09 Sep 05 @ 5:56 pm
VDJ only works with VDJ vinyl
geposted Fri 09 Sep 05 @ 8:54 pm
You don't NEED the amp from Final Scratch or anything from them.
You need buy VDJ + Maya 44 USB (or equivalent) + 2 TCVs.
You could use your licensed VDJ to use in the second computer if you (only you ) use both and only you use VDJ.
geposted Sat 10 Sep 05 @ 3:16 am
