"This application has failed to start because VCL35.bpl was not found. Re-installnig the application may fix this problem."
I'm not sure exactly what I did to cause this error, but does anyone know anything about it. I searched the forum and couldn't seem to find anything similar. (I know that I could just reinstall, but I thought that if there was a problem, other people might come up against the same thing so it would be good to bring it up.)
geposted Mon 26 Sep 05 @ 4:53 am
. . . anyone?
geposted Tue 27 Sep 05 @ 6:37 am
It has something to do with dynamic link library. (.bpl means Borland Package Library). You didn't mention what OS you are running. Is it Virtual DJ that don't work? Or another program?
Here is a link to that file, put then in C:\\WINDOWS\\SYSTEM
but I don't know if it will work.
http://www.cord.edu/faculty/ulnessd/pchem/kt_calc/vcl35.bpl
Hope it works, but keep informed if it doesn't.
geposted Tue 27 Sep 05 @ 7:41 am
