Hi
Virtual DJ use to add tracks to the playlist panel when i dragged a track on to a deck.
VDJ no longer does this.
Does anyone know how I can turn this feature back on?
Thanks
Jon
Thanks
Jon
geposted Wed 26 Oct 05 @ 12:16 am
Click on the circular button that looks like a two arrows in a circle, 4th from the top all the way to he right in the playlist area, and your problem should be solved
geposted Wed 26 Oct 05 @ 12:29 am
Hi vantinedj
Thanks for your reply ....
Do you mean the "Bring the playlist in the filelist" button?
If you did then i tried that and it did not resolve my issue - :( - Tracks that I drag on to a deck still are not being added to the playlist panel.
Regards
Jon
Regards
Jon
geposted Wed 26 Oct 05 @ 8:39 pm
Strange. What version are you using? It works in 3.1 and 3.0.
geposted Wed 26 Oct 05 @ 9:14 pm
3.1
The button that you described does not seem to "stay on" - unlike the lock panel, automix buttons for example...
geposted Thu 27 Oct 05 @ 3:22 am
@melquaides: The button that Vantine is talking about is the 'recycle' button, not the 'bring playlist' button. It causes every song that you play to get added to the end of the playlist.
geposted Thu 27 Oct 05 @ 10:32 pm
I think that was what you were talking about, but you say it won't stay on? Is there an option for this? I didn't think so. Anyone else have any ideas?
geposted Fri 28 Oct 05 @ 3:09 am
Fixed!
It was the recycle button that was not on....
Thanks ... I'm happy again!
Jon
Jon
geposted Fri 28 Oct 05 @ 3:39 am
