Hello,
Did the skin system change?
The new skin files are not .ZIP and are not recognized by VDJ.
How do i install them?
Thanks
Thanks
geposted Sun 30 Oct 05 @ 6:19 pm
Indeed the new system compilates as an .exe so install it like an usual program: all is automatic now
The new system concerns skins, sound plugins, visual plugins
geposted Sun 30 Oct 05 @ 9:54 pm
Just rename the skin file that you downloaded by adding .exe to the end of the filename and double-click to install it.
Cheers
Cheers
geposted Wed 04 Jan 06 @ 3:39 am
Thank you very much it works....
Still doesn't sort out my problem with ointer as a black square....
I'll try to sort it other way round...
Cheers...keepmixrockin'....
geposted Tue 24 Jan 06 @ 5:48 pm
geposted Thu 23 Feb 06 @ 7:04 pm
geposted Thu 23 Feb 06 @ 7:05 pm
If you bought Virtual DJ please enter your serial number
geposted Thu 23 Feb 06 @ 7:06 pm
In your profile too ;-)
geposted Thu 23 Feb 06 @ 7:13 pm
