I puchased the Download Virsion of Virtual DJ on 10-30 for $149 (Order Number U13235359)
I downloaded it to an external hard drive where I store all my programs to first check for any Viruses. Nortons found none so I transferd it to my laptop C drive. After installation, I tried to play VDJ only to find several error messages:
1 Internal Data Base is Corrupted,
2 Invalid Skin File (error line % in the XML,
3 Error opening XML Plugin File,
4 Protection Error7
But not nesseserally in this order.
Mabe the Uninstalled Trial Version was in conflict with the puchased version?
I have since uninstalled the Trial Version but to no avail.
Can I just uninstall the the Purchased Version from my external hard drive
and attempt to Re-Download VDJ directly to my C Drive on the laptop?
I was happy with the trial version, this is why I bought this program!
I'm DJing a Christmas Party and would like to show off Virtual DJ to all my Friends!
Thank you for all your help!
~joe
4 Protection Error7
~joe
geposted Tue 01 Nov 05 @ 4:10 am
Think anti virus should be disabled when installing. Try re-downloading it and re-install it. Make sure everything is proparly un-installed first. Hope this helps out for you.
geposted Tue 01 Nov 05 @ 12:51 pm
For the protection error, send a message to http://www.virtualdj.com/contact
geposted Tue 01 Nov 05 @ 3:15 pm
I've recently bought atomixmp3 and later lost it by having my pc formatted. How do I re-download the program without r-paying? thanks
geposted Thu 11 Oct 07 @ 11:39 pm
Go to the top of the forum and click on download center, add your forum password and u should see ur download
geposted Fri 12 Oct 07 @ 12:01 am
Glad to see another person join and see the fun in using VirtualDJ! :-)
Go to this page to download the "VirtualDJ Registry Key Removal" program to clean out your registry before reinstalling VirtualDJ.
geposted Fri 12 Oct 07 @ 3:18 am
