new update comming up.
new features are :
- records.
choose vdj records
or special djjb records. (vdj-logo is button)
- gain and volume sliders in mixer are changed.
you can choose both / volume or gain for each player.
- cuenames diplayed. (by second click on cue-time)
- set-cue-lock-pannels are changed.
buttons are gone when locked.
- 12 sample-buttons.
included load-buttons for each sample.
- level-visuals are changed.
you can choose "position of slider" or "output level".
- clock is bigger than before.
- nudge / scratch buttons.
for mouse and/or console. (nudge also for the records)
- other beat-visuals.
two transparent and two onof. (realy nice)
- sync-buttons.
placed in a better position. (in mixer)
hope i didn't forget something. and that you like it, the way it is now.
greatings...
djjb
new features are :
- records.
choose vdj records
- sync-buttons.
greatings...
djjb
geposted Thu 03 Nov 05 @ 12:49 pm
nice man ...this is my #1 skin right now. I love the placement of options and the BIGGER BPM display from default size. What do you mean special djjd records??? do records on the turntable change? or the function of them do?? any previews? thanks ..good work!
geposted Thu 03 Nov 05 @ 3:11 pm
I didn't think it would get any better, I was wrong. Nice.
geposted Thu 03 Nov 05 @ 3:25 pm
the record change. and olso avaleble for nudge.
the virtualdj on the record can be changed for my special djjb logo.
geposted Thu 03 Nov 05 @ 4:12 pm
Very nice..... but i'm not sure what you mean on different beat visuals? is there a button? great job on the new features, i just wish i could use my own logo :)
geposted Fri 04 Nov 05 @ 6:16 pm
in the old skin there where only two leds going on-of.
now there are 4 leds. 2 on-of and 2 transparent.
i just wish i could use my own logo :) ?
sent me yours... maybe i can do it..
thnx for your reply.
geposted Fri 04 Nov 05 @ 10:25 pm
@djjb
1. will you be making these same changes to your 'browser' stlye skins?
2. your 'browser' style skins should be included under 'variations' of your advanced default skins.
geposted Fri 04 Nov 05 @ 10:55 pm
sorry heyward... don't know what you mean..
my english isn't that good..
geposted Sat 05 Nov 05 @ 12:04 am
You had 2 other 'advanced' skins, uploaded in the skins directory.
The first one was called 'advanced default eco.' and it did not have any decks.
The second one was called 'advanced default modern' it had metallic silver buttons and no decks.
Will you be updating these skins also?
geposted Sat 05 Nov 05 @ 12:50 am
Hello everybody.
I most wanted one file to Pioneer CDJ 100S skin.
The .XML file is missing.
Please evreyone send me if is possible.
Please it is very very importent for me. :-(
geposted Sat 05 Nov 05 @ 1:24 am
now i got yah hayward..
i have to...i think..lol..
but that's comming later.. i wasn't working for the last 2,5 years, but now i have a nice jop.
so i don't have much time anymore. but i love to do it.
geposted Sat 05 Nov 05 @ 1:34 am
good work djjb, you are the best skinmaker.....
but 1280x800 version ?
but the beatlock button ... don't lock
re try now
Ciao from Italy
Spazialex DJ
re try now
Ciao from Italy
Spazialex DJ
geposted Sat 05 Nov 05 @ 7:16 pm
advanged default modern is updated
geposted Fri 11 Nov 05 @ 1:01 pm
Your new skins work very well, good luck with your new job and keep up the good work.
When you have time I have some other skin ideas I would like to propose, but for now I am enjoying these updates.
geposted Mon 21 Nov 05 @ 3:40 pm
new update...
2 skins in 1 zip. video and non-video.
and a lot more..
and a lot more..
geposted Mon 19 Dec 05 @ 10:35 am
Hello Djjb
I like a lot your advanced default skin and it's the best with the hercules console, but do you think it's possible to invert the button sequence 1-2-3 to 3-2-1 (invert 1 to 3) for the FX in the left deck, in the console is 3-2-1 for left and 1-2-3 for right.
Thanks in advance
Thanks in advance
geposted Mon 19 Dec 05 @ 3:35 pm
After same test I think it's good to invert all the left deck button to have a good mirror for the hercules console, but after this the skin will be totally different, can you make a special skin for hercules dj console?
If I press the pitch bend + or - on the console i don't see the button goes down-up in the skin.
The pitch speed font (+..%) is to small, can you change the font size?
When I go to the right side to press the sample button with the playlist area close this automatic open, do you think it's a godd idea to have the sample in the left side of the screen near the explorer area?
Another idea is, if you move little up the crossfader tone area and insert 4 little button for the crossfader curve selection (F=Full C=Cut Sc=scratch Sm=Smooth) up to the crossfader slide.
The button nudge or scratch are very good!!!
Thanks
Thanks
geposted Mon 19 Dec 05 @ 7:19 pm
thnx cioce...
I give you my answers.
1.invert all the left deck buttons to have a good mirror for the hercules console, but after this the skin will be totally different, can you make a special skin for hercules dj console?
I can but i don't have a lot of time.
2.If I press the pitch bend + or - on the console i don't see the button goes down-up in the skin.
That's normal.
3.The pitch speed font (+..%) is to small, can you change the font size?
I already changed that.
Do you think it's a godd idea to have the sample in the left side of the screen near the explorer area?
very good idea, i'll do it
4.4 little buttons for the crossfader curve selection (F=Full C=Cut Sc=scratch Sm=Smooth) up to the crossfader slide.
Done that to.( forgot the scratch, but it's comming up later)
That's normal.
geposted Tue 20 Dec 05 @ 7:00 am
Thnx Djjb for the very fast answers!!!
I don't understand why you use the gray color for the FX button, when the button is not press it's so hard to find, is a good idea the color white like all the other button? On the LCD screen the gray color is not the best.
Bye :-)
Bye :-)
geposted Tue 20 Dec 05 @ 9:15 am
hi again..
don't know why i did that.. DONE !!
also inverted the fx buttons for player 1
geposted Tue 20 Dec 05 @ 11:16 am
