I have created a shortcut for my slideshow in VDJ so that the pictures only change when I hit the home key. This used to work fine until about 2 updates ago.
It still works to SOME extent. When I hit the shortcut key one image will flash and then the next image will appear. In essensce, you are seeing 2 images with one press of the key.
If you have an even number of pictures to display then you will never see half the pictures. If you have an odd number of pictures then you will see the first half on the first run and then the second half on the second run.
Does that make sense?
geposted Sun 13 Nov 05 @ 8:05 am
it does. make sure that momentarily etc is not selected in the shortcut and all the other options are set correctly as to not think that on pressing and on releasing are two different commands, mabey .....lol who knows
geposted Mon 14 Nov 05 @ 2:30 am
