If I install this update, will have to start over again creating cue points and playlists, or does prior information automatically get transfered?
geposted Tue 22 Nov 05 @ 4:18 am
you need to backup the VDJ datatabase xml file first (probably in c:/Program Files/VirtualDJ). then I suggest to add/remove your old vdj, install the 3.2. then copy the database file back to its original place
geposted Tue 22 Nov 05 @ 7:49 am
You shouldn't need to backup the database first...
but in the world of personal computers, sometimes things go wrong.. :)
So make backup before install can be good, just in case...
I installed 3.2 without needing to uninstall 3.1 first, or backing up database etc
geposted Tue 22 Nov 05 @ 8:47 am
The good answer is:
You have to learn to regulary backup your database and your music and everything,
since you choose to work with computers as Dj in Norway said...
These are the rules..
However the update is safe.
geposted Tue 22 Nov 05 @ 11:55 am
