I have plugged in a mic into my soundcard and I want to record jingles - but nothing happens when I click on the record button, in fact the system locks up. Should I be modifying something in the menu? I've checked the levels on the mic, that is turned up to its highest level so am I doing something wrong?? Any help will be appreciated!!
geposted Wed 23 Nov 05 @ 12:30 pm
I am pretty sure that the Record function within Virtual DJ is for recording Mixes of what is playing, not for recording the Mic input. You can get either "Total Recorder" or "Audacity" To accomplish what you want.
geposted Thu 24 Nov 05 @ 12:07 am
I think you can with "Master+Mic" ;-)
geposted Thu 24 Nov 05 @ 12:50 am
I've tried that from the Record File Config settings and nothing happens!! But thanks anyway!
geposted Thu 24 Nov 05 @ 5:56 pm
I don't think it's possible to record mic input into jingles/loops. Correct me if I'm wrong, but I don't think I am :)
geposted Thu 24 Nov 05 @ 6:51 pm
I personally found that plugging my mic into my soundcard was a bad idea...cos the quality was terrible. Can't you plug into your mixer?
P
P
geposted Thu 24 Nov 05 @ 8:13 pm
DJCel ''I think you can with "Master+Mic" ;-)"
I Need To know Where Master+Mix is cuz i've been looking for it for a while
because i do internet radio and ain't got no mic with VDJ ... so where is this
Master+Mix button ?
Master+Mix button ?
geposted Sun 27 Nov 05 @ 6:13 pm
Master + Mic is in the Record settings in VDJ [I think??]
geposted Mon 28 Nov 05 @ 5:00 pm
Yes since vdj v2.1 in records and broadcast
geposted Mon 28 Nov 05 @ 7:14 pm
