Hello !
Im about to buy the mk2 , and I found an old Lenco L80 belt drive turntable in my garage.
If I can the change the cartdrige , is there anyway I can use TCV with it ? Im sure it will work but I dont know if its reliable to use with VDJ.What do you think ??
geposted Sat 26 Nov 05 @ 5:26 pm
depends it its realy meant for djing , how hight the torque is and ull need a slipmat cause using the rubber one that normal TTs have on them will not let you move the record without moving teh platter with it. may be worth simply getting some beginner turntables but its up to if you think you can get it settup in such a way that you will be able to dj with it.
geposted Sun 27 Nov 05 @ 10:18 pm
