I keep getting this message on every start up "Direct X sound driver error". What's the fix?
Thanks - JD
Thanks - JD
geposted Tue 06 Dec 05 @ 11:35 pm
go to soundcard settings in VDJ, and select the correct soundcard/setup....
Quit VDJ, and restart... the error message should be gone :)
the message usually just means that the soundcard configuration you have set, is wrong
geposted Tue 06 Dec 05 @ 11:41 pm
Much Thanks! -
That worked great.
That worked great.
geposted Wed 07 Dec 05 @ 1:08 am
i keep gettin a Direct x sound driver error when i try to open up the virtual dj ... and suggestion on how to fix it??
geposted Sun 25 Dec 11 @ 3:37 pm
