Why native ASIO drivers of U46DJ doesn't work with VDJ?
It is an ESI issue or an VDJ issue?
thanks
thanks
geposted Wed 07 Dec 05 @ 2:48 pm
U can get it to work fine in DJ decks but their are still a few probs aparently but ESI are woking to fix em ;)
geposted Thu 08 Dec 05 @ 12:42 am
gbravetti,
The problem is from ESI drivers, and maybe the could solve this in the near future. For now you could work with u46DJ and ASIO4ALL with VDJ.
But please first, buy your full license of VDJ ;-)
Good Luck!
Good Luck!
geposted Thu 08 Dec 05 @ 6:30 am
I use U46DJ perfectly after the 3.2 update, but like acw said, buy the full version and you'll be very satisfied. The sound quality is even better with U46DJ native ASIO drivers compared to ASIO4ALL.
geposted Thu 08 Dec 05 @ 8:35 am
I'm choosing right now wich hard/soft I'll be working with, of course if I decide to work with VDJ I'll buy it,
Mantahoe, you said that with 3.2 you can work with ESI U46DJ ASIO drivers without any problem? Really?
geposted Thu 08 Dec 05 @ 2:44 pm
Yes, that's what i'm using right now. It works fine. Before the 3.2 update, I had to use ASIO4ALL. Just buy the software, you'll be satisfied. I just bought mine like a month ago and I have no complaints at all.
geposted Thu 08 Dec 05 @ 6:53 pm
