Hi
Some songs the beats (BeatMatch on ) are not locked in place with each other, they are a split second away from each other...Any tips how to correct it exept to switch to manual "match" button every time?
Thx in advanced
Fl@me
Thx in advanced
Fl@me
geposted Thu 08 Dec 05 @ 9:04 pm
Sync botton sync on beats...
But beatmatch/lock buttons sync according to CBG.
The Computer Beat Grid is the dots under the beats....
You have to make sure they are aligned to the beats, if Virtual DJ sometimes dont do that automatically.
in many skins you can adjust the CBG's by pressing buttons in skin
geposted Thu 08 Dec 05 @ 9:27 pm
button in skin? What skin is that? And what button is it...?
thx
Fl@me
thx
Fl@me
geposted Fri 09 Dec 05 @ 5:31 am
Mix Station SV 04 is one. It has not been updated for 3.2, (missing a few buttons), but still works fine.
geposted Fri 09 Dec 05 @ 8:16 am
@flame
you can also adjust CBG's by keyboard shortcuts, if you favorite skin does not have such buttons...
Look in my blog for a full guide to such keyboard shortcuts :)
geposted Fri 09 Dec 05 @ 2:40 pm
You could try changing autoBPM in the FAME settings to Enabled rather than Smart.
HTH
Jon
HTH
Jon
geposted Sun 01 Jan 06 @ 10:17 pm
