How do you make samples over 4 beats using VDJ?. I'd like to use the internal system to synch my samples but the loop only records to 4 beats.
geposted Tue 20 Dec 05 @ 10:14 pm
the loop records for as many beats as you want ;)
Try it.... make a 32 beat loop for example in your Vdj player, go to a sample slot, and record it :)
Voila - a 32 beat loop in sample slot ;)
VDJ - so powerfull, so easy ;)
geposted Tue 20 Dec 05 @ 10:25 pm
I love mixing like that but it takes time to set it up. But once you have prepared all the samples and tracks...a work of art is created. Love your style dude...very similar to mine. Very enjoyable.
MS
MS
geposted Wed 21 Dec 05 @ 1:55 am
this stuff shows me what i lacked top kudos dude ..... now how about those samples toooooop stuff ;-)
any chance of some relesed samples from ya ;-)
geposted Wed 21 Dec 05 @ 5:14 am
DJ-In-Norway
I mean when you hit LOOP for recording samples it only records 1 Bar or 4 beats. I want to use the Beat Sync (Beat, Quarter and Half Quarter) function from LOOP record and that's not available with the Jingle record function.. It seems to be only available with LOOP record function.
Thanks
Thanks
geposted Wed 21 Dec 05 @ 10:42 pm
"..mean when you hit LOOP for recording samples it only records 1 Bar or 4 beats..."
Yes, thats the default value.
The default value apply if you have not set a loop on the chosen deck
But, if you make a loop on the deck for say 32 beat loop, and then hit record in sample slot, the loop that is saved is 32 beats! ;)
geposted Wed 21 Dec 05 @ 10:46 pm
I've tried that by taking a song and hitting 8,16 & 32 for a loop....I hit record and it still records only one bar. What am I doing wrong.
geposted Wed 21 Dec 05 @ 11:57 pm
bmac16: Make sure your loop is on (Blue light on) when you are saving it or play your loop on either deck and save it on the sample while is playing if not it only records 4 beats.... Use your shortcuts for large beats on loops.
geposted Thu 22 Dec 05 @ 4:05 am
Dj VNZ,
Thank you very much for sharing your knowhow. You have a very clever way to make vdj as your tool. I
think vdj team should consider seriously the way how you use their product and extend this function in
vdj future version. Anyways, they need few directions to strengthen fuctions for future Virtual DJ for
competitive strategy purpose. You and the team can both benefit.
Thanks again.
DJ Artimix
Thanks again.
DJ Artimix
geposted Sat 24 Dec 05 @ 5:24 am
yo VNZ i like your mixes...
you can basically even make your instrumentals with the samples but you need to get the instrumental packages...
but i dont get it do you use jingles and loops? with the samples you use?
geposted Sat 24 Dec 05 @ 7:14 am
Just listened to the Gosadera Mix. Sounded it real good. Sounds like it takes a long time to set up.
Try this whenever you get a chance with Hip Hop and R&B...
Play a loop instrumental in one of the sample slots. Put an acapella in each deck and play the acapellas in sync with the instrumental. Continue adding various acapellas. Sounds real good and it is done live.
MS
MS
geposted Sat 24 Dec 05 @ 4:48 pm
I wanted to share with you all (the "Double Impact" contest break) in a club (Tremors) in South Florida back in 1995 ( No Virtual Dj around ). This is My self and a buddy of my (Dj Thunder D) going at it on 4 technics and 2 Staton mixers. In all the weeks there the club had dj's like Jealous J , Billy E, Johny Quest, Exoctic E and others. This was a fun event. I sold all that equipment a while back and I wish I can scratch like that now with virtual Dj. Anyway, I edited the club anoucement on 95.5 FM and added it on the background of the break.
Sound is a little crappy since I had this on an old TDK tape. Listen to it, Enjoy and dont laugh too much.
http://www.acidplanet.com/artist.asp?songs=445002&T=7886
VNZ
VNZ
geposted Mon 02 Jan 06 @ 5:24 pm
I knew two DJs named Double Impact that played on B96 here in Chicago about two years ago. Must have been a group of people named that. Sounds good though. Brings back some memories.
MS
MS
geposted Mon 02 Jan 06 @ 8:15 pm
I listened to ur mixes, incredible stuff man! You are the king of VDJ!!! Amazing effects and preparations! It's mind boggling to even think the mixes were created live and then retracked for efx. Great job, u should definitely consider a job w/in the VDJ staff to help in coordinating new ideas for this program. Ur headed in the right direction w/ this. Now it needs to be seen if VDJ will consider what you have done w/ this program, and update fresh ideas from a very talented dj like yourself. Excellent!
geposted Wed 11 Jan 06 @ 4:54 pm
my brother your mixes are very nice !!! te felicito me encanta los mixes que has echo de musica tropical y latina. Buena brother, eres una inspiracion para un newbie como yo. DJ IV4N !!!
geposted Fri 20 Jan 06 @ 4:17 am
Thanks again for the feed back from all of you.
I posted a video of Dj thunder D and My self scratchin on the 3500 dennons. I like to know if I can do this with the xp10's. I might be interested in buying if it's possible.
http://www.acidplanet.com/artist.asp?videos=445002&T=1404
geposted Wed 25 Jan 06 @ 5:00 am
4 New Mixes. Especially the freestyle Super mix where I put VDJ to the max. Enjoy.
I will record a video clip soon of me live using the sampler for my next megamix. Will upload soon.
Later....
Later....
geposted Thu 02 Mar 06 @ 1:41 am
Hi DJ VNZ, i tried to listen to your megamix at the acid planet site but was unsuccessful. Could you send me another link where i can hear the megamix. Cheers Bro
geposted Thu 26 Apr 12 @ 3:11 pm
that link is 7 years old, why dig up this thread....
geposted Thu 26 Apr 12 @ 3:34 pm
