Anyone notice that when you leave the pitch sliders on the dac in the middle where it locks it locks on -0.2? Looks to be a bug should be 0.0.
geposted Fri 16 Dec 05 @ 3:10 am
Mine lock at -0.1 (Left) and -0.2 (Right) - I also had the same problem on the D-Vinyl controller that I owned a while back (But sold after getting TCV and XP10's.)
In my DAC-3 mapper DLL (Which is almost finished now for v1.0), I've added a pitch calibration option, which allows you to adjust them so they lock at 0.0
geposted Fri 16 Dec 05 @ 7:41 pm
Yea. For now I just set option to auto pitch reset. If it gets left on -0.2 the sound sounds wierd when you load a song
geposted Sat 17 Dec 05 @ 12:11 am
